2013 Best Practices Awards to Gas-Turbine-Based Plants – Combined Cycle Journal
NEWINGTON
Continuous-blowdown block valve reduces startup time, plus. . .
Breaker retrofit protects transformer
Triple-redundant sodium analyzers protect equipment, personnel
more
KLAMATH FALLS
Replacing a closed-code FT8 control system
more
ENCOGEN
Transitioning a legacy base-load plant to cycling duty
more
OLYMPUS DIGITAL CAMERA
EFFINGHAM
Reducing LP drum pressure increases cold-weather output
Equipment supports core-skills training, proficiency
Arc flash data sheets, labels create a user-friendly program
Better organization of paperwork in the control room pays dividends
more
NV ENERGY FLEET
Workforce design using Hoshin planning
more
JOHNSON COUNTY
Optimizing chiller operation
Membrane installation/removal tool reduces physical stress
more
SEVIER
Collaboration, focus on constructability result in efficient design meeting challenging schedule
Adapting vent stack design to handle flashing of process-steam drains
Voltage-class evaluation results improve cost-effective performance
more
LEA
Ammonia-tank level monitoring contributes to high plant availability
Hydrogen system modification improves safety, balance sheet
Wastewater reclamation project produces big cost savings
more
HOLDEN
Control system mods enable 10-min starts; increase reliability, flexibility
more
DOGWOOD
Inline repair saves 9-chrome HP stop/check valve
Management training for day-shift O&M technicians
Extreme-weather preparedness increases availability
more
McCLAIN
Improvements to plant permit process benefits safety
more
ROKEBY
Comprehensive hazardous spill mitigation strategy
more
GRANITE RIDGE
Chemical delivery drivers welcome safety cards
Wireless monitoring of HRSG drain valves pinpoints energy waste
Communications initiative leads to multi-faceted returns
Engineered solution to facilitate generator inspections
more
SALTILLO
ACC fan-blade pitch optimization
Gas-turbine-inlet air filtration improvement
Fuel-oil recirculation arrangement saves money, mitigates spill risk
more
SABINE COGEN
Safety database developed in-house effectively tracks, validates contractors
Monitoring CEMS gas bottle pressure ensures compliance
more
MEAG WANSLEY
Post-maintenance checklist for critical instruments
‘Scratch out’ accidents program promotes safety vigilance
more
FARIBAULT
Freeze protection, Minnesota style
HRSG chemical feed system improvement
more
ATHENS
Detecting pump issues before they cause outages
more
KIAMICHI
Severe-storm, tornado readiness key to personnel safety
NERC CIP-006: physical security perimeter challenges
more
CROCKETT
Student internship program helps combat aging workforce
more
HARQUAHALA
Safe practices for inspecting, maintaining cooling towers
more
HIGGINS
New, safer method of rigging halves time for ACC gearbox change-out
more
BRIDGEPORT
Preparing plant, workforce for hurricane conditions
more
BUNDY
Natural-gas blowdown system assures a safer working environment
more
LINDSAY HILL
Cooling-tower automated basin temperature/two-speed fan control
Removable platforms in cooling-tower fan shrouds improve safety
more
OSPREY
Start faster, earn more
Seasonal readiness refresher training
more
TERMOEMCALI
Well water, bypasses, new procedures eliminate debris issues on plant starts
Fuel-tank retrofit helps preserve biofuel
more
TRACY
ACC gearbox oil removal piping
GT hazardous-gas monitor access mod
more
ARROW CANYON
Multi-facility horizontal management planning
more
LENZIE
Steam-line drain valve inspection program
more
WASHINGTON COUNTY
Using condition-based vibration monitoring for critical equipment
more
WALTON COUNTY
Reducing hydraulic-oil system varnish
more
AL SANDERSVILLE
Commitment to conservation reduces annual electric bill by $100K
more
KLEEN ENERGY
Contractor management program advances culture of safety
more
CENTRAL ALABAMA
New valving protects against damage to tubing, piping
more
JUNIPER ENERGY
New process conducive to more accurate financial reports
more
