CCJ Archives: 3Q 2008
How clocking of compressor blades may impact wear in some vane rows
Have you ever thought about why people remember you, and how little what they remem­ber you for might reflect about your professional abilities?
An example: Many graying read­ers probably recall Bowzer, the gan­gly greaser of Sha Na Na, a popular rock ‘n’ roll band of the 1970s and 1980s. more
Virtually everyone who works in a powerplant knows that clean heat-transfer surfaces are criti­cal to achieving the low­est possible heat rate. In combined-cycle plants, the heat exchangers having greatest impact on perfor­mance are the heat-recovery steam generators (HRSG) and condensers. This arti­cle is about the former. more
The global economic downturn will impose new challenges on plant operations. It’s difficult to believe that you will be asked to do more with a smaller budget, but you will. However, approaching these new challenges with a positive mindset can yield significant ben­efits. One might be that your junior staff is forced to learn more about power-generation processes, equip­ment, and systems, thereby increas­ing the level of expertise onsite. more
How to verify proper operation of bypass, spray-water valves
Steam-turbine bypass sys­tems are used in combined-cycle plants during startup, shutdown, and load rejection. The most common arrangement, shown in Fig 1, allows plant opera­tors to route high-pressure (HP) superheated steam through a pres­sure control valve/desuperheat­er station to the cold-reheat line, thereby bypassing the steam tur­bine’s HP cylinder. This typically is referred to as the “HP bypass.” more
CDMS helps prevent forced outages, tune engine after overhaul
Most gas-turbine (GT) users familiar with dry low-emissions (DLE) com­bustion systems have heard the acronym CDMS, short for combustion dynamics monitor­ing system. This certainly sounds important, and it is. But the term “combus­tion dynamics” and what it means to GT owner/opera­tors often is not well under­stood at the plant level. more
‘Leave no stone unturned’ when developing O&M contracts
By Jeffrey J Fassett, PE, IEM Energy Consultants Inc
Structural changes to the elec­tric power industry over the last decade or so have made asset owners more willing to pay third parties to assume roles they themselves once held exclu­sively. The underlying reason typi­cally is risk mitigation. Some gen­erating facilities are now owned by one company (or a consortium), operated by another, managed by another, with major maintenance performed by yet another or others. more
