501F GAS TURBINES: Repairs never-ending? Replace problematic exhaust systems
Exhaust systems are a presentation and/or discussion topic at most gas-turbine user-group meetings, particularly those supporting F-class and the more advanced frames. Cracking of components, broken struts, material distress, and leaks at joints are almost sure to occur in virtually any system handling a 1000 lb/sec or more of turbine exhaust at 1000F or higher and moving at near mach speed—especially so in starts-based engines with original equipment (Fig 1).
There was a period a few years back when the accepted “solution” was to have personnel standing by to make repairs during annual—or semiannual—outages. In meeting after meeting, discussion focused on weld material, weld configuration, welder qualifications, expansion joints, and related topics. It came to be that users able to restrict repairs to every other outage were recognized for their acumen by peers.
The effects of hot gasses leaking from cracks into areas where they could cause accelerated wear and tear and/or personnel hazards provided owner/operators the incentive to press for root cause analyses and resolve the problems through better design and materials selection. There was a lot of finger-pointing to be sure, mostly directed at the gas-turbine OEMs. However, that might not have been entirely fair given the limited industry experience available to guide the design of early F-class units.
The OEMs of record—Siemens Energy Inc and Mitsubishi Hitachi Power Systems Americas Inc—upgraded the designs of their exhaust cylinders and manifolds (Fig 2) for the 501F series of engines to eliminate the issues experienced. These have been retrofitted at several plants, as discussed in some CCJ articles published over the last several years. They can be accessed by using the search function on the magazine’s home page at www.ccj-online.com.
More recently, Ansaldo Energia Group’s PSM, headquartered in Jupiter, Fla, has expanded its 501F aftermarket product line to include exhaust systems. The first complete PSM exhaust systems were retrofitted in NV Energy’s Silverhawk Generating Station (Unit B) and Walter M Higgins Generating Station (Unit 2) prior to the 2017 summer run.
Both plants, which began commercial operation in 2004, are 2 × 1 combined cycles powered by Siemens 501FD2 gas turbines. The utility plans to replace the exhaust systems on Silverhawk Unit A and on Higgins Unit 1 during their next major outages—provided upcoming inspections/evaluations confirm expected performance.
Background. The 501F exhaust system has two principal components: an exhaust cylinder, connected to the turbine case on its inlet side and to the exhaust manifold on its outlet side (Fig 2). The cylinder may be of single- or two-piece construction. PSM’s “drop-in” replacement is a horizontally split two-piece cylinder, the only option available for pre-501FD3 machines when they were purchased. This configuration typically is preferred by users because they can maintain their current maintenance practices in future outages.
Depending on component dimensions, a spacer piece may be required downstream of the exhaust manifold to fit up with the heat-recovery steam generator. An expansion joint is located at the round-to-square transition between the manifold or spacer and the HRSG. In the case of a simple-cycle unit, there would be no HRSG and the manifold or spacer would connect via an expansion joint to the transition piece directing exhaust gas to the stack.
Scott Amos, a gas-turbine subject matter expert in NV Energy’s central engineering group, and Fatima Bouzidi, maintenance manager at Silverhawk, walked the editors through the 501F exhaust-system challenges their company faced—including the following:
  • Failure of static seals, allowing hot exhaust to contact bearing support struts, causing overheating and cracking which allowed the aft bearing and rotor to “drop.” The rotor drop reduced critical compressor and turbine radial clearances to the point where metal-to-metal contact between the casing and rotating components became a concern. Experience of other users is that a crack can propagate quickly, extend through the entire strut, and force the unit into an outage with extensive damage.
Thus timely strut repair and clearance correction are recommended to prevent the possibility of a wreck. Repairs and realignment are expensive undertakings, to be sure. Remember, too, that access to the aft bearing for inspection and the taking of measurements on legacy equipment is not a simple matter. In NV Energy’s experience, it takes about a day and a half to cool an exhaust system with compromised seals before you can drop down through the manway and crawl forward to the bearing.
  • No end to the cracking/repair cycle experienced with the exhaust cylinder. This was due, in part, to failure of the baffle plates illustrated in Fig 3, allowing recirculation of exhaust gas to the dead-air space. PSM’s “fix” prevents recirculation and the casing creep issues attributed to it (Fig 4).
Exhaust gas also can overheat expansion joints, allowing them to leak and create safety and environmental issues. Repairs are time-consuming and expensive, and never “final.”
Another manifold concern: Cracking of the flat panel portion of the manway and the liberation of material. Primary causes were believed to be acoustic excitations and the impulse loading created by separation of the exhaust flow stream attributed to the manway’s teardrop design. Fixes included weld repair of plate and the addition of stiffeners to address the excitation issue.
Designs of the PSM and original OEM exhaust manifolds are illustrated in Fig 5.
NV Energy’s engineering team had been following industry experience on 501F exhaust systems for years, while continually evaluating the condition of its Silverhawk and Higgins units, before deciding on a course of action for its assets. Amos said after receiving multiple alerts from the OEM and listening to owner/operator colleagues at forums such as the 501F Users Group, it was obvious that repairs are temporary and the only long-term fix is replacement of the exhaust cylinder.
Bearing drops on the four 501Fs at Higgins and Silverhawk were monitored by PSM. Fig 6 reflects the relatively constant drop in rotor centerline position of Higgins 2 over time, averaging about 10 mils annually. Silverhawk B experienced a more severe drop: about 15 mils per year on average (Fig 7).
With the future easy to predict, NV Energy engineers conducted detailed design reviews of replacement exhaust systems offered by the two OEMs and PSM. The company focused on reliability improvements and reduced maintenance promised by the offerings. Its goals were the following:
  • Eliminate exhaust-bearing drop.
  • Improve the low-cycle fatigue life of the cylinder and its struts.
  • Improve system durability in all modes of operation, with a focus on cycling.
  • Reduce the thermal constraint on the strut shield.
  • Improve the exhaust-cylinder/HRSG connection and protect the HRSG inlet expansion joint.
  • Provide better access to areas that may require repairs.
  • Assure compatibility with the existing structure, piping, and other connections.
Major design changes by PSM (from the original exhaust system) to achieve the goals bulleted above were these:
  • Change exhaust-bearing support struts from Type-410 stainless steel to a nickel-based super alloy.
  • Redesign exhaust cylinder and manifold support structure, and improve aerodynamics.
  • Eliminate baffle seals by integrating a new manifold front flange into all PSM exhaust installations.
  • Reduce thermal stress by making changes to material geometry.
  • Change diffuser and strut shield to Type-347 stainless steel from Hastelloy®.
  • Redesign exhaust-cylinder and -manifold gas-path seals.
  • Minor design changes by PSM are the following:
  • Increase thickness of exhaust-cylinder inner and outer liners, and the manifold liner.
  • Mating surfaces are scalloped to minimize thermal stresses; a thickness gradient also is used to achieve the same goal.
  • Implement filleted radius.
  • Improve the expansion-joint interface. CCJ
