Recent Generator Findings And Preparing Generator Rotors for Cyclic Duty
THURSDAY, DECEMBER 3, 2020 @ 3pm EST/12pm PST
Presentation Synopsis
Recent Generator Findings presentation will include a percentage breakdown of work in the MD&A shop over the last 18 months in addition to case studies defining: why the unit was brought down, the root cause, the applied repair, and if it was planned work or emergent / forced outage work. Preparing Generator Rotors for Cyclic Duty presentation will include case studies with cycling impacts on generator rotors with actual findings and applied repairs.
Key Takeaways for Users
1 – Be thorough in your investigation when a unit is down, and document everything. Most items can be viewed overtime and will give clues to when a failure will occur. Review these documents before an upcoming outage so you have a good baseline on where you have been.
2 – If your unit is down for any length of time utilize a borescope and get your eyes on the machine (if possible) and take note of everything you see. It never hurts to get additional eyes on your system even if it isn’t a planned outage.
3 – Regular maintenance of the unit should not be delayed if possible. A rigorous inspection and maintenance schedule should be followed whenever possible.
Presenter
James Joyce, Generator Services Operations Manager
James joined MD&A in 2015 and worked several years on the road as a Generator Specialist. He was promoted to the Operations Manager role in 2019 and has been supporting the Generator Specialists on site since then. He has an engineering degree in Mechanical Engineering from the University of Missouri and has been enjoying living in St. Louis since he began working for MD&A.
Contacts
James Joyce
JJoyce@MDATURBINES.com
+1-(314) 880-3000
About MD&A
Mechanical Dynamics & Analysis (MD&A) provides power generators around the globe with a full-service, OEM-alternative for services, parts, and repairs for Gas Turbines, Steam Turbines and Generators.
In our 35 years, our commitment to excellence has earned customer trust for all turbine-generator needs. We focus on delivering consistent quality and value with fast response, superior communications, and innovative solutions.
MD&A is easy to work with. We provide immediate access to expert help when you need it, where you need it. Around the corner or the globe, we ensure prompt, thorough communication and follow-through. For every repair job, large or small, the speed and effectiveness of our response team is matched only by the depth and breadth of our engineering expertise.
Find out today why so many power generators use MD&A to maximize operational effectiveness.
Products and Services
GAS TURBINE SERVICES
Outage Planning
Technical Direction
Turnkey Inspections
Gas Turbine Alignment
Coupling Laser Alignment
Operational Alignment Diagnostics-CMM System
Field Machining
Balancing & Vibration Analysis
Control and Excitation Field Engineering, Consulting & Training
End of Life Evaluation
Thermodynamic Analysis
Thermographic Survey
Performance Testing & Analysis
Turbine System Enhancements
Turbine Foundation Monitoring
Center-line Installations
STEAM TURBINE SERVICES
Outage Planning
Technical Direction
Turnkey Labor
Topless Alignment ®
Custom Installation of Seals
Field Machining
Steam Path Audits
Turbine Engineering
Remaining Life & Finite Element Analysis
Turbine Control Retrofits
Acceptance Testing
GENERATOR SERVICES
Robotic Generator In-Situ Inspection
Outage Planning
Technical Direction
Turnkey Labor
Generator Testing & Inspections
Generator Excitation Retrofits
GAS TURBINE PARTS
Frame 7FA Parts Solutions
Frame 7EA Parts Solutions
V Series Parts Solutions
Fuel Nozzles
Combustion Parts
Compressor Parts
Turbine Parts
Gas Turbine Bearings
Oil Deflectors
Fasteners
Legacy Turbine Circuit Boards, Repairs & Service
IBECS System- Power Plant Control & Monitoring
STEAM TURBINE PARTS
Steampath Components
Stationary Components
Valve Components
Combined Cycle Valve Drop-in Solution
Main Stop Valve Upgrade
Guardian® Packing
Vortex Shedder® Spill Strips
Conventional Packing & Spill Strips
Custom Seal Installation
Tapered Land Thrust
Tilt Pad Thrust
Elliptical Journal
Tilt Pad Journal
Oil Deflectors
Bronze Seal Rings
Fasteners
Steam Turbine Retrofits
GENERATOR PARTS
Generator Stator Bars
Collector Rings
Hydrogen Seal Rings & Assemblies
Insulated Bearing Rings
Oil Deflectors
HV Bushings & Auxiliaries
Fasteners
Miscellaneous Generator Components
Generator Retrofits & Replacements
GAS TURBINE REPAIR
Rotor Repair
Component Repair
Fuel Nozzle Repair
Compressor Vane Pinning Solutions
Portable Machine Shops
Machining Services
High Speed Balance
Rapid-Spares Gas Turbine Bearings
Bearing Ball Ring Repairs
Tapered Land Thrust
Tilt Pad Thrust
Elliptical Journal
Tilt Pad Journal
Oil Deflectors
Bronze Turbine Seal Rings
STEAM TURBINE REPAIR
Machining Services
Stationary Component Repair
Rotating Component Repair
Rotor Straightening
Casing/Shell Analysis & Renovation
Distortion Correction
High Speed Balance
High Pressure Valve Repair
Turbine Valve Actuators
Westinghouse® Horizontal Throttle Valves
Steam Seal Regulator
MHC Operating Governor
Control Pac Power Actuators
Overspeed Governor
Control Rotor
Tapered Land Thrust
Tilt Pad Thrust
Elliptical Journal
Tilt Pad Journal
Oil Deflectors
Advanced Rotor Welding
GENERATOR REPAIR
Stator Repair
Generator Field Repair Services
Stator Bar Water Leaks (TIL-1098)
Rotor Slot Dovetail Repair (TIL-1292)
Collector Ring Machining
High-Voltage Bushings & Auxiliaries
High Speed Balance
Hydrogen Seals & Housings
Elliptical Journal
Tilt Pad Journal
Oil Deflectors
Website
Address
19 British American Blvd E
Latham, New York 12110
United States
